rear mount distributor
Old Mar 29, 2005 | 10:18 AM
LT1 Bunny's Avatar
what kind of distrbutor are those with mounting them in the rear running? I havent bought mine yet and its the last piece missing. dont know if i should run the 85551 msd or what??
shed some light on me please!
Old Mar 29, 2005 | 01:24 PM
Jameslt1TA's Avatar
Re: rear mount distributor
I think that msd or mallory makes a very flat distributer that would fit easier under the cowl of our cars. That is if clearance would be and issue. If no i like mallory's HEI..its only like 150 bucks and works great...i love hei distributers. Look in a summit mag...i cant seem to find mine.
Old Mar 29, 2005 | 01:31 PM
mojorisin's Avatar
what all is involved in putting in an actual distributor like this?
Old Mar 29, 2005 | 01:39 PM
andysc's Avatar
Not trying to hijack your thread, but I am wondering if you could use a distributor off a
L31 vortec engine. This has the crab type cap with the plug wires horizontal to the engine. The reason I am interested is I am thinking of putting a lt1 in my 1999 GMC Yukon, ditching the opti and using the distributor from the vortec. since I want to 4 wheel. But this distributor should work in a f body as well. Will probably have to get creative with the egr valve though.
Interested and looking for more info
Andy Schuck
Old Mar 30, 2005 | 07:00 AM
LT1 Bunny's Avatar
I think as long as youhave room and its for an sbc you can use it. All our block are is a 327 just modified differently. SHould be ableto use any distributor we want. At least that what I'm thinking.
Old Mar 30, 2005 | 08:57 AM
LT1 Bunny's Avatar
there are actually a few different ways you can go with this. A few people send the intakes off and get a hole drilled in the back of the intake. And then of course you would take out the oil pump drive because the end of the distributor has your gear on there.
or you can go the way I'm going and go all carb. everyone will say its stupid and pointless and its bad gas mileage and yada yada yada. For me though, a very big cam has bad gas mileage. Then my tuners can even get the car to run the way I want it to. Its just easier for me and my friends to throw it on the dyno and change jets and tune the motor that way. But if you want to go the carb way, you need an afpr, carb, intake you want to get (might need machining, depends on what intake you want), and then the distributor. Of course your going to need small little things here and there as well.
HectorM52
Jul 30, 2017 11:46 AM
HarleyZ28
Oct 5, 2015 06:23 AM
REDNECKISBOSS
Mar 22, 2015 08:31 AM
Jazsun
Dec 29, 2014 12:14 PM
