Rear Main Seal Removal questions.
Old Sep 30, 2004 | 07:38 PM
Silvershark's Avatar
I am in the process of removing my rear main seal so I can remove the crankshaft and I am unable to dislodge it.
It says to tap with a plastic hammer in my book, however this method is not working and I do NOT want to break anything.
I looked on shoebox's website but I was only able to find an image of the rear main.
How does the seal remove? I have removed the nut on the right hand side going horizontal and the bolt on the left side going horizontal. Is there something that I have to do with those studs in order to remove the rear main?
Here is the pic off of shoebox's site.
http://shbox.com/1/rear_main.jpg
Thanks.
Old Sep 30, 2004 | 07:59 PM
nateh's Avatar
Re: Rear Main Seal Removal questions.
If you are trying to remove the crank, you do mean that you're trying to remove the rear main seal housing, right? The rear main seal is inside the housing and keeps the oil on the inside.
If you have taken out all the bolts, it should slide rearward. There is a gasket between the housing and the block, and if it gets stuck, you might need to tap it a little.
Old Sep 30, 2004 | 08:00 PM
Spinner's Avatar
There's Six bolts/studs holding the housing in place. Four on the front, and one on either side facing vertical (oil pan). Just tap it lightly with a deadblow hammer, it'll pop loose and it'll slide/pry off
Old Sep 30, 2004 | 08:02 PM
Im in the process of rebuilding my engine so I am tearing it down now so I can send the block to the shop. Right after I posted this I looked at shoebox's picture a little more and noticed that there were 2 bolts on the very bottom. I am going to try and remove those.
Sorry for wasting everyone's time.
Im tired from working on this damn thing for the past couple days and I am starting to overlook things.
I am going to run to the store and get some beer and relax after this removal. I will be done for a bit until the machine shop does it's thing.
Old Sep 30, 2004 | 08:15 PM
Spinner's Avatar
It helps if you take them all out.
Old Sep 30, 2004 | 08:44 PM
Well, I am done for a while.
http://www.akgaming.com/videos/engine.WMV
Old Sep 30, 2004 | 10:18 PM
92rslt1's Avatar
proud of your build i can tell .. just take your time and do it once. mine looks the same right now as yours.
Old Sep 30, 2004 | 10:26 PM
4 fasteners hold the housing to the block. The 2 studs on the housing are to fasten the rear of the oil pan to it.
Old Sep 30, 2004 | 10:44 PM
Yup, hopefully when I get paid tomorrow I can get this thing all machined and ready to rock and roll. It's taken me a month so far just to get it where its at. I like to remove a little here and a little there and then go inside and work on it another day. If I would have worked on it straight I prolly could have had it done in 3-4 days for sure. But where is the fun in that?
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
Mar 13, 2016 03:39 PM
4586
Jan 3, 2015 07:22 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
squarehead
Nov 21, 2014 08:02 PM
