Rear Main Oil leak symptoms?
Just rebuilt the bottom end, and I literally fired it up about 2 hours ago. No leaks initially, but after I ran the engine to 200 degrees, I drove her back in the driveway and noticed one drop of oil on the ground, and one little drop on the crankshaft seal housing. So I jacked her up and ran it for another 5 minutes and nothing. Is it possible residual oil on the seals housing as I lubed it before installing?
Anyways, what symptoms are definitely a rear seal leak.
I used the Right Stuff on the Intake, and it has new oil pressure and temp sensors with good teflon, and WIX filter. Oil pan was put on with FelPro one piece and Rigth stuff in all 4 corners.
Well, I drove it slowly today through slow city streets to work, and as soon as I parked it a drop of oil fell. Then I turned it off, waited a while and nothing. Then about an hour later there was a little more oil on the wood I left underneath it.
So, I drove it home on the highway at/up to 80 mph with 3,75 gears so it was doing 3000 rpms for a couple miles. Came home, parked it and nothing.
I jacked it up and will cehck it when I get home.The back of the manifold, intake type, is dry. I will look at it again at home, as it is jacked up, and I may run it in the air like that and see if something happens. This is an odd leak.
I used Fel Pro rubber, and only put a little oil to assist in putting it on.
Well, I looked at the area down there. The oil pan has oil between the pan and the blue rubber of the FelPro at the base of the housing of the rear main seal, so not the flat part of the gasket against the block. The Flexplate is dry. There was oil on the housing of the rear main seal, but I couldnt feel any oil on the side of the seal housing where the seal is, and with a que tip barely anything was there. I am thinking it is the pan gasket.
I am going to have to run it, on the jacks and watch it. Then shut it off and see what happens.
No smoke behind me or any burning, and transmission pan is dry.
stockssn2o
May 25, 2015 08:54 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
