rear main
Re: rear main
Run you hand along the back of the intake where the intake joins with the block. You'll pull back an oily hand if the intake is leaking. The only good way to tell if the rear main seal is leaking is to pull the tranny. Also look along the valve covers where they meet the heads for leak sources.
Re: rear main
Before you start tearing into things, make sure it's not coming from the oil filter. I went through about the same thing. Went out and bought the RMS and everything. Thank god I found a small nick where my filter is supposed to seal. I woulda been a little upset to say the least if I would have spent the time pulling it apart to R2 the seal
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
