Are rear jounce bumpers really necessary?
Old Feb 3, 2004 | 08:06 PM
PatriotTA's Avatar
Before I put my car in storage for the winter I noticed that the rear jounce bumpers (those bumpers at the top of the inside of the wheelwell) were dry rotted. So I removed them since they surely weren't doing any good like that. Should I replace them, and if so, does anyone know if there is a polyurethane replacement part available?
Old Feb 3, 2004 | 08:15 PM
brokenz's Avatar
I've never seen a pair that didn't look dry rotted. They are necessary so I would just put the old ones back on. I don't know if a poly replacement is available.
Old Feb 3, 2004 | 08:21 PM
RacinLT1's Avatar
i havent had those for 3 years,and the car was a dialy driver for 2. only time i ever noticed them not being there was 1 night i didnt see a crater in the road and hit it at speed,no damage,just a lound "clunk".
Old Feb 3, 2004 | 08:43 PM
brokenz's Avatar
I agree that on most cars it's unnecessary. I guess it would depend on the amount of clearance you have inside you rear tire well. Not knowing his wheel/tire combo then I guess it would be OK to run that way if he would just pull the rear coil springs, bottom the car out, and see if he's gonna have a tire hit anything in the fenderwell. I still don't see why someone wouldn't just leave them in though.
Old Feb 3, 2004 | 09:24 PM
RacinLT1's Avatar
they blocked my 15x10's from fitting easily,and where they were mounted too was cut away for tire clearance.
Old Feb 3, 2004 | 10:07 PM
94_Camaro_LT-1's Avatar
Went to Advance and they hadn't a clue ... they said it is prob a dealer only part ... I guess I wont be replacing mine either then hehe
Old Feb 3, 2004 | 10:43 PM
CamaroBoy96Z28's Avatar
SLP sells jounce spacers for larger diameter wheels. I think they're $25.
Old Feb 3, 2004 | 11:20 PM
brokenz's Avatar
:werd: The bolts are also long enough that you can do the same thing with some washers. I'm running 17x11's in the back.
Old Feb 3, 2004 | 11:21 PM
Heatmaker's Avatar
Advanced Member
I cut mine and pushed them back about anhalf an inch or so when I slapped the X11's in...They serve some prupose...had a nice wear pattern from them on my Axle housing.
Old Feb 4, 2004 | 06:11 AM
Mtrhds94Z's Avatar
I bought new ones last year sometime for under 10 apiece..
The rubber was white not black tho..
Old Feb 4, 2004 | 06:20 AM
The bumpers are a good idea... keep them. When you bottom out the shocks, you can damage them, particularly if you are running adjustables.
My 17x11/315's required cutting the outer edge off the bracket, but nothing else.
Jounce bumper surgery.....
Old Feb 4, 2004 | 10:53 PM
Link? Or part number? hehe
Old Feb 4, 2004 | 11:34 PM
From my part numbers page:
1993-1997 rear jounce bumper 10164173 and they have gone up about 50% in price since I put the number on my page. Maybe it is because they are white like Charlie said.
Old Feb 5, 2004 | 06:21 AM
Mtrhds94Z's Avatar
I got them from Gm dealer [Jason Cromer] fall of last year...
Old Feb 5, 2004 | 07:04 AM
brokenz's Avatar
I'm sort of curious as to if anyone knows why they are different now.
