Rear End install help
Old Feb 22, 2004 | 01:42 AM
1995ta's Avatar
http://mofbody.com/forums/viewtopic.php?t=4496
Old Feb 22, 2004 | 01:53 AM
InjectedSS's Avatar
Re: Rear End install help
DUDE Your supposed to pull the axles BACK AFTER you install the c-clips... So you push the axles all the way in, put the c-clip on and then pull on the axle as if you were going to pull it back out and VLOIA good to go
Old Feb 22, 2004 | 08:59 AM
1995ta's Avatar
We tried that, no luck.
Old Feb 22, 2004 | 10:18 AM
Rodrigues's Avatar
So loosened the nut holding the roll pin in, removed the pin and C clips to push the axles back in? Also you sure that posi is 28 spline and not 26?
Old Feb 22, 2004 | 12:28 PM
1995ta's Avatar
I wouldnt know. The rear came out of a 2001 SS Camaro. It has an Auburn posi
Old Feb 22, 2004 | 12:49 PM
$hawn's Avatar
Pretty sure thats a torsen posi unit if it's out of a 2001, and it has this kinda of a rectangle shaped block that slides down in there and you put the retaining bolt in it, I assume you dont have that block that goes in the middle?
Old Feb 22, 2004 | 03:40 PM
1995ta's Avatar
I think so...
Old Feb 24, 2004 | 01:57 PM
1995ta's Avatar
TTT
Anyone?
Old Feb 24, 2004 | 08:59 PM
$hawn's Avatar
Which part is holding you up now?
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
Collector Car
Jan 5, 2015 10:58 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
