Rear control arms
Old Jun 16, 2003 | 02:28 PM
Got-LT1's Avatar
Question Rear control arms
What do they do and are they worth $80 for my car? Will they lower ets at all?
Old Jun 16, 2003 | 02:51 PM
LWillmann's Avatar
New control arms and bushings will help plant the power to the ground more efficiently... A worthy mod for even a car that's not raced.
Old Jun 16, 2003 | 03:10 PM
The rear lower control arms locate the axle assembly front-to-back relative to the body. When you launch, the LCA's are the only thing that pushes your car forward. If they flex, have sloppy bushings, or don't keep the correct angle relative to the ground, you will get a lot of wheel hop, and poor traction.
Old Jun 16, 2003 | 03:31 PM
Cmr0z28's Avatar
howdy Fred, MattZ28 here from ws6zxr
Is it worth getting new LCA's? or would the poly bushings that came with the ES Hyper-Flex set be good enough until I'm running more HP?
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
thenewkid
Nov 27, 2014 09:41 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
slothgrant
Aug 22, 2002 03:01 PM
