crank position sensor?
Old Aug 23, 2005 | 08:52 PM
95okz28's Avatar
does the crank position sensor have to be connected? or is it there just to detect a miss if it occurs?
Old Aug 23, 2005 | 09:34 PM
95okz28's Avatar
Re: crank position sensor?
ttt
Old Aug 23, 2005 | 11:22 PM
OBE1 95Z28's Avatar
If you have an OBDII car, you need to have the crank position sensor functional. You didnt give us any car info...you screen name implies you have a 95, that OBDI and doesn't have a crank position sensor.
Old Aug 23, 2005 | 11:25 PM
The crank sensor on LT1s is for misfire detection only. It will not affect spark delivery. Most other cars/engines will not run with the crank sensor.
Old Aug 23, 2005 | 11:29 PM
ss#1230's Avatar
i forgot to connect the crank position sensor once on my car and it wouldnt start. finally realized what the problem was. started right up after i plugged it in.
Old Aug 24, 2005 | 11:55 AM
95okz28's Avatar
my problem is that the car and pcm and harness is all 95 but the engine and exhaust system is from a 96-7
Old Aug 24, 2005 | 12:14 PM
sssalah's Avatar
That's no problem at all, this sensor on OBDII cars is only for misfire detection, it'll throw a code on 96-97, but the enige should start and run fine. Your 95 PCM will not be expecting this such signal anyway
Old Aug 24, 2005 | 02:27 PM
Eff's Avatar
Eff
Since the opti can discern the Cam position with 1/720th of a rotation it can be used to emmulate the CPS very accurately. As long as the timing is set correctly.
98+ need the CPS.....
Old Aug 24, 2005 | 03:55 PM
OBE1 95Z28's Avatar
I'm running a 96 engine in my 95; just leave the sensor in place (to block the hole in the timing chain cover); there's no mating connector in the 95 harness as it wasn't used therefore no issue.
Old Aug 25, 2005 | 01:10 AM
ss#1230's Avatar
hey sssalah, unplug your crank sensor and try to start the car. id like to see if starts. mine didnt, as stated above. just wondering if my car is weird.
Old Aug 25, 2005 | 07:01 AM
CANTONRACER's Avatar
I have not ran in my last few combos with no issues. In fact, even if I did have it plugged in, I have a washer where the plate used to be taking up the space.
It is not needed.
Old Aug 25, 2005 | 11:46 PM
sssalah's Avatar
Hi, I've already done that before, not only on one but 2 OBDII LT1's , and you know what I didn't even get a light, but that's probably due to the "export" PCM having some error codes disabled.
Old Aug 26, 2005 | 12:46 AM
lt11997's Avatar
You learn something new everyday. I was taught in school that an engine with a crank sensor won't run at all without one.
Old Aug 26, 2005 | 12:52 AM
ss#1230's Avatar
well thats true with my car. dunno what the difference is.....
Old Aug 26, 2005 | 08:11 AM
It's probably the only engine that does this. The optispark is used for crank position, so it does not need the sensor. It was only added because of OBD-II requirements for misfire detection.
HectorM52
Jul 30, 2017 11:46 AM
VF-124
Mar 16, 2015 08:14 PM
eazyZ
Mar 1, 2015 07:12 AM
Queens94z28
Dec 20, 2014 09:11 PM
Injuneer
Dec 15, 2014 09:36 AM
