is it really true???
Old Mar 23, 2004 | 04:59 PM
sleeper94z28's Avatar
is it true that an oiled air filter can mess up your your bands and clutches and set off SES lights???
Old Mar 23, 2004 | 05:06 PM
FacelessZ's Avatar
if you oil your filter you need to let it dry then you'l be fine...a lot of people simply oil them and put them right back in...
this can cause your MAP readings to be off and knock all sorts of stuff out of wack...
Old Mar 23, 2004 | 05:08 PM
Did you read the "announcement" at the top of the page? Can't get any clearer than that.
http://web.camaross.com/forums/annou....php?forumid=9
Old Mar 23, 2004 | 05:19 PM
FacelessZ's Avatar
and for those of us who arent still under warranty, you bear the chance of everything named in that announcement...
as long as you dont over oil your filter and as long as you let it dry you'll be fine...
Old Mar 25, 2004 | 05:06 PM
yes i did read the announcement ,where do you think i got the idea... i can understand oil getting in you MAF and messing things up but that still has nothing to do with the clutches and bands in your tranny... i asked b/c i keep havin problems with my tranny going out (twice in 6 months)
Old Mar 25, 2004 | 05:17 PM
Hawk's Avatar
engine and tranny, hmmm, i think you answered your own question
Old Mar 25, 2004 | 05:24 PM
anaik's Avatar
How does oil dry?
Old Mar 29, 2004 | 10:29 AM
never mind you guys obviously have no idea what you are talking about
Old Mar 29, 2004 | 10:46 AM
Pretty basic auto mechanics is going to tell you that no air the engine inhales goes into your transmission. I guess the odd nature of your question threw people off. Maybe they thought it was a joke.
Before you start pointing fingers, you might want to consider if you know what you are talking about.
Old Mar 29, 2004 | 11:02 AM
Hawk's Avatar
Obviously we don't know what we are talking about, please move this to advanced tech to explain the path of intake air and how it enters the tranny,
Also, your nitrous kit could be freezing the gears in the tranny causing them to bind, look into that as well.
Old Mar 29, 2004 | 11:41 AM
dkeers's Avatar
The PCM decides what line pressure the tranny will use based on various sensor inputs. If these sensors are giving false readings (because of oil on them or another reason), you will get a line pressure that is too high or too low. This could cause your transmission problems.
Old Mar 29, 2004 | 02:45 PM
I don't know of any time it directly uses the MAF or IAT for any transmission calculations, though (mostly TPS and VSS for MPH). The MAF or IAT would be the only sensors that would get oil on it from an over-oiled filter.
Old Mar 31, 2004 | 10:29 AM
okay thanks for the info... sorry about the misunderstanding
RUENUF
Mar 13, 2016 03:37 PM
generaldave
Sep 25, 2015 06:48 PM
Slayer
Aug 17, 2015 03:55 PM
meissen
Aug 11, 2015 06:05 AM
