Is It Really Necessary To Change To Vented Opti When Doing Cam Change??
Just wondering if it is really that big of a deal to change over to a vented opti when doing a cam change...
Please give me any and all info on this subject you have...i've DONE SEARCHES by the way...lol
Randy
Randy
Is it neccessary? No..
Is it a 'big deal'?
That's relative.. [to what you consider a big deal..]
You need to swap the opti, cam, timing chain, timing cover, opti harness[wiring], and add an opti vacuum vent harness..
Quite a bit of work .. BUT if doing a cam swap most all of the above is removed anyway..
That's why many do it then..
And if you didn't find this in a search you're searchign the wrong subject.. it's discussed over and over here..
Is it a 'big deal'?
No, it is not necessary, but there are some things to consider:
-if you are or soon will be in need of an opti, the vented opti is $100 cheaper (however, you will have to get a different timing cover plus buy the electircal and vacuum harnesses)
-you will have many more choices for timing gear sets (if you keep the non-vented opti, you are virtually stuck with only using the stock type set)
If these things are not important to you, then don't worry about upgrading.
armedtrigger
Feb 24, 2015 08:30 PM
