Really Bad Shaking Idle Problem???
Old Jun 30, 2006 | 11:59 AM
  #16
95BlackTA's Avatar
Re: Really Bad Shaking Idle Problem???
I have the same problem as you...mine doesnt shake bad enough to shut off the car, but it shakes at idle as well as driving...heres what I replaced...
New IAC(which helped the underlying dropping RPM problem I had..but the shake is still there)
Opti
Coil
Plugs/HALF THE WIRES...Im thinking this is my problem, I never got around to changing all of them...Im going to do this next...
Cleaned MAF/TB
Im in the process of readjusting all of the Rockerarms to Zero lash...a while ago a few of my rocker arms loosened up, so I think some of them are off. I hope that'll fix the problem, if not...then im off to the wires.
Old Jun 30, 2006 | 05:48 PM
  #17
OneFreakZ's Avatar
Unhappy Re: Really Bad Shaking Idle Problem???
yah i had in mind that it might be something do with the ignition but im going to replace the wires and the IAC hopefully this is the problem...but if not im going to replace the opti and coil as well.....thanks
Old Jul 1, 2006 | 02:33 PM
  #18
OneFreakZ's Avatar
Thumbs up Re: Really Bad Shaking Idle Problem???
yeah im going to check on the ignition system hopfully its something simple like a burnt wire or something but yeah im going to clean the IAC...thanks for all your help..
Old Jul 3, 2006 | 05:17 PM
  #19
OneFreakZ's Avatar
Question Re: Really Bad Shaking Idle Problem???
yeah i think it has something to do with the ignition system..no this is the first time this has happend to the car??...thanks
Old Jul 3, 2006 | 05:55 PM
  #20
1racerdude's Avatar
Pull all your plugs and check the gap. If ya got exotic metal plugs the tip on one of them may have come off and there is too much gap to fire.
Set them on .035 before ya put them back. That will make it easier to fire and eliminate the plugs as a cause.
Old Jul 3, 2006 | 06:06 PM
  #21
blown94's Avatar
Check your plug wires on the passenger side near the ac compressor. Best to check at night, witha spray bottle full of water. Soak down the plug wires and watch for fireworks, not the ones in the sky, the ones under your hood. Id be willing to bet one has touched the exhaust or gotten too close and melted. Been there, done that.
Old Jul 4, 2006 | 12:13 AM
  #22
OneFreakZ's Avatar
arent the spark plugs supposed to be gab at factory gabing which i think is 0.50????..yeah ill be checking those wires this weekend..so in order to see the fireworks do i have jack up the car and look from under the car????..hey thanks for all your guys help
Old Jul 4, 2006 | 12:20 AM
  #23
1racerdude's Avatar
.035 makes it easier for the opti to fire them.
Old Jul 4, 2006 | 08:42 AM
  #24
OneFreakZ's Avatar
crazy i didnt know that...ill remember that..thanks
Old Jul 4, 2006 | 09:08 AM
  #25
1racerdude's Avatar
The .050 plug gap was put there for idle emissions.
The plug gap IS resistance in the system and the more the resistance the harder it is to fire. Your wires,and plugs already have a resistor built in and when an opti gets a little weak it won't fire the BIG gap like it should causing the spark to back up in the opti and causing carbon tracking and ruining it.
The only thing a BIG gap does is that it is good for emissions and sells opti's and tune ups.
Old Jul 4, 2006 | 12:44 PM
  #26
OneFreakZ's Avatar
oh ok i see so should i go ahead and change out the plugs and wires again??..and gap the plugs at 0.35..thanks
Old Jul 4, 2006 | 12:52 PM
  #27
1racerdude's Avatar
Not if they are OK.Ya need to check them first.
Old Jul 4, 2006 | 01:21 PM
  #28
OneFreakZ's Avatar
cool thanks
Old Jul 4, 2006 | 05:35 PM
  #29
JohnD's Avatar
I had the problem you describe and I traced it down to a missing platinum electrode on the ground side of the #6 plug. Put back in an old plug and the problem went away completely.
Old Jul 5, 2006 | 03:23 AM
  #30
OneFreakZ's Avatar
oh yeah the #6 plug is on the passenger side right...becuz ive notice when i started the car there is like a clicking noise coming from the passenger side like where the plugs and wires are....so i think its a bad or burnt wire but ill check this weekend...i just hope its nothing series ...thanks
