Really Bad Shaking Idle Problem???
on my 94 camaro z28 did tune up about 4,000 miles ago it has new opti,coil pulgs and wires never shak like this before all of sudden it starts to shak really bad while its on park to the point when it shuts off at times??...any ideas guys please help:confused: :( and suggestions please..Thanks
Re: Really Bad Shaking Idle Problem???
Do you have anyway of datalogging it?
Could be a bad opti, knock, running too rich or too lean at idle, clogged IAC, dirty maf, etc. |
Unplug the maf and see how it runs.
what do you mean datalogging it puting it on the a scanner??...yeah ill try unpluging the maf lets see how it turns out??..thanks
well i unplug the maf and the car turned off...but every time i turn the car on it smells like its running rich and like a gas smell coming from the tail pipes?????..any ideas guys.:confused: :mad:
hello guys any one out there?????please :( ..
So it didn't run without the maf? It might take a few tries to get it going. Just unplug it and try to start it. Clean the IAC?
Is it throwing any codes at all? |
ok check it out what i did was turn on the car and disconnected the maf while its running then it would shut off i didnt try starting the car while the maf is disconnected ill try that tomorrow...so what is the IAC again it slip my mind???...no codes no check engine light????....thanks
yea try it with MAF disc. heres a pic of the IAC, f/ shoebox:
http://shbox.com/1/iac3.jpg that needs to be cleaned so it will seal properly, and the housing it seals to as well, but don't force it in/out. |
hey i try starting the car with the maf disc and the car would not start..???...thanks
I had the same problem your having and someone recommended that I clean out my IAC. I cleaned it up and it worked. It now idles great. Does it run fine after you give it gas? Does it only do it when you have the a/c on or when you turn your steering wheel while at idle? If so, it's probably the IAC. Those were the symptoms I had.
on my car it idles really shaking for as long as i have the car running even when im driving????and when i give it gas it still shakes and it back fires even if im giving the car alittle gas it still back fires???...but yeah how do i clean the IAC????....thanks
First make sure you go to the store and get a throttle body gasket. Take out the 4 screws holding the the throttle body onto the manifold. Then disconnect any lines that need to be disconnected from the TB in order to be able to move it so you can get to the IAC. I found it easier to just disconnect everything and remove the whole throttle body. It only took about 10 minutes to get it off and 10 more to get it back on. Either way it's an easy job. Hopefully that will help your problem.
hey did your car when it would shake did it do it all the time even when your driving??..thanks for the info ill give a shot...thanks
