Really Bad Shaking Idle Problem???
Old Jun 28, 2006 | 02:20 AM
OneFreakZ's Avatar
Angry Really Bad Shaking Idle Problem???
on my 94 camaro z28 did tune up about 4,000 miles ago it has new opti,coil pulgs and wires never shak like this before all of sudden it starts to shak really bad while its on park to the point when it shuts off at times??...any ideas guys please help and suggestions please..Thanks
Old Jun 28, 2006 | 08:36 AM
Gripenfelter's Avatar
Re: Really Bad Shaking Idle Problem???
Do you have anyway of datalogging it?
Could be a bad opti, knock, running too rich or too lean at idle, clogged IAC, dirty maf, etc.
Old Jun 28, 2006 | 09:07 AM
tyrsmkr's Avatar
Unplug the maf and see how it runs.
Old Jun 28, 2006 | 04:53 PM
OneFreakZ's Avatar
Question Re: Really Bad Shaking Idle Problem???
what do you mean datalogging it puting it on the a scanner??...yeah ill try unpluging the maf lets see how it turns out??..thanks
Old Jun 28, 2006 | 06:00 PM
OneFreakZ's Avatar
Unhappy Re: Really Bad Shaking Idle Problem???
well i unplug the maf and the car turned off...but every time i turn the car on it smells like its running rich and like a gas smell coming from the tail pipes?????..any ideas guys.
Old Jun 28, 2006 | 08:45 PM
OneFreakZ's Avatar
hello guys any one out there?????please ..
Old Jun 28, 2006 | 08:55 PM
tyrsmkr's Avatar
So it didn't run without the maf? It might take a few tries to get it going. Just unplug it and try to start it. Clean the IAC?
Is it throwing any codes at all?
Old Jun 29, 2006 | 12:44 AM
OneFreakZ's Avatar
Exclamation Re: Really Bad Shaking Idle Problem???
ok check it out what i did was turn on the car and disconnected the maf while its running then it would shut off i didnt try starting the car while the maf is disconnected ill try that tomorrow...so what is the IAC again it slip my mind???...no codes no check engine light????....thanks
Old Jun 29, 2006 | 08:31 AM
Blue96z28's Avatar
yea try it with MAF disc. heres a pic of the IAC, f/ shoebox:
http://shbox.com/1/iac3.jpg
that needs to be cleaned so it will seal properly, and the housing it seals to as well, but don't force it in/out.
Old Jun 29, 2006 | 05:36 PM
OneFreakZ's Avatar
Thumbs down Re: Really Bad Shaking Idle Problem???
hey i try starting the car with the maf disc and the car would not start..???...thanks
Old Jun 29, 2006 | 08:38 PM
NYC32798's Avatar
I had the same problem your having and someone recommended that I clean out my IAC. I cleaned it up and it worked. It now idles great. Does it run fine after you give it gas? Does it only do it when you have the a/c on or when you turn your steering wheel while at idle? If so, it's probably the IAC. Those were the symptoms I had.
Old Jun 29, 2006 | 09:06 PM
OneFreakZ's Avatar
on my car it idles really shaking for as long as i have the car running even when im driving????and when i give it gas it still shakes and it back fires even if im giving the car alittle gas it still back fires???...but yeah how do i clean the IAC????....thanks
Old Jun 29, 2006 | 09:44 PM
NYC32798's Avatar
First make sure you go to the store and get a throttle body gasket. Take out the 4 screws holding the the throttle body onto the manifold. Then disconnect any lines that need to be disconnected from the TB in order to be able to move it so you can get to the IAC. I found it easier to just disconnect everything and remove the whole throttle body. It only took about 10 minutes to get it off and 10 more to get it back on. Either way it's an easy job. Hopefully that will help your problem.
Old Jun 30, 2006 | 01:19 AM
OneFreakZ's Avatar
Thumbs up Re: Really Bad Shaking Idle Problem???
hey did your car when it would shake did it do it all the time even when your driving??..thanks for the info ill give a shot...thanks
Old Jun 30, 2006 | 07:27 AM
Blue96z28's Avatar
I don't think its the IAC if it even shakes while accelerating......but the IAC is probably dirty if you've never cleaned it, so it needs to be cleaned anywayz. But if you have a violent shake while accelerating or free reving, its something else, I would think ignition - maybe burnt wire after install? bad opti or coil? Did it have these symptoms before you changed the opti/coil/wires/plugs? Same? Worse? Maybe motor mount?
