Real Quick LT1 Head question.....
Old Apr 29, 2005 | 10:47 AM
BlkLT1Z28's Avatar
What of the two Aluminum heads are the better ones? I cant remember.
TIA
Old Apr 29, 2005 | 12:22 PM
96capricemgr's Avatar
Re: Real Quick LT1 Head question.....
The early ones flow less as cast but offer more meat for porting, the later flow more as cast but are thinner with less room to port. Answer depends on what is your definition of better?
I would not go through the trouble of swapping out old casting for new for the small as cast flow difference either. I do not have the casting numbers handy either but hopefully this has you pointed to what you wanted to know.
Old Apr 29, 2005 | 12:39 PM
BlkLT1Z28's Avatar
Thanks, I need to find out which ones had more room for porting.
Old Apr 29, 2005 | 12:46 PM
Sanger's Avatar
The 561 cast heads are the heads that came on 96-97 camaros. I forget the casting numbers of the 93-95 cars. The difference was about 10% more air flow or so with the 561. There was a comparison I found on here one time, maybe you can search for it.
Old Apr 29, 2005 | 12:47 PM
RE AND CHERYL's Avatar
The early casting was used from 92 to sometime mid 95.
Old Apr 29, 2005 | 01:23 PM
BlkLT1Z28's Avatar
So the earlier ones have the most meat on them for porting? (92-95)
Old Apr 29, 2005 | 04:38 PM
Sanger's Avatar
Yes
Old Apr 29, 2005 | 04:49 PM
LT1OWNZ's Avatar
Where is the casting # located? Do i have to pull a valve cover to check to see what i have?
F'n1996Z28SS
Aug 23, 2023 11:19 PM
rideordie
Nov 5, 2019 04:52 PM
tweetybirdy
Sep 10, 2002 02:36 PM
Absolute Z28
Jul 19, 2002 02:21 PM
