real easy gauge question
Old Feb 5, 2004 | 03:46 PM
formulav8281's Avatar
well finally today i got under the formula to unscrew the screw to run my psi gauge.well u guys says its a screw right above the oil filter.well i could not get that screw off.so i need to know another way to run my guage.any suggestion.i have the mechhinacial gauge.thanks.
Old Feb 5, 2004 | 04:14 PM
Your only other choice is to "tee" off the existing location of the oil pressure sensor behind the intake.
Did you use a 6 point socket and a long bar? IMO, it sure would be a lot easier by the filter than behind the intake manifold.
Old Feb 5, 2004 | 05:35 PM
i used a 15 in socket ranch and tried to get it off.i have the extension but that wont help much would it?its the perfect location cause its easier but i dont see the sending unit behind the mainfold.well the guages gave me some adaports and connectors.well help me out.also which way i should be turning the socket.now i hit rock bottom.haha
Old Feb 5, 2004 | 07:03 PM
Lol, counter-clockwise to remove it. (you are working on the plug that is just under the label "Digits 10-17..." in this pic?)
See what I mean? You can't even find the existing sensor, so how are you going to work with it?
99TransAmWS6
Feb 12, 2015 07:23 PM
cmdeshon
Dec 27, 2014 10:06 AM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
