Ready to put her back together, what else do i need ?
Old Sep 17, 2003 | 11:30 AM
Van5150's Avatar
I am ready to put back together the woman and looking to see what else I need to do the job with minimal stops to Autozone.
I have about 2 gallons of antisieze compound.
I know I need gasket maker stuff for the front and rear of the intake to stop that leak.
I see a few components had orange stuff on the threads, like the knock module, what is that ?
Banjo Gaskets, do they need any lubricant ?
Am I missing anything?
Old Sep 17, 2003 | 11:33 AM
BradZ28's Avatar
What are you putting back together? Heads/cam, just a waterpump, engine rebuild?
Van5150's Avatar
Heads, Intake, Exhaust. My bad..
Old Sep 17, 2003 | 01:08 PM
InjectedSS's Avatar
you'll need..
4 gallons of MIXED coolant (DEX COOL) the orange stuff... they have it at autozone, get the ZEREX PRE-MIXED
intake gaskets
header gaskets
timing cover gasket
waterpump gaskets
copper rtv sealant for the front and back of the intake
silver rtv for the waterpump gaskets
and a throttle body gasket
think that's it
Old Sep 17, 2003 | 02:02 PM
Van5150's Avatar
Really, I want to use the Orange Dex ? I thought I heard things.
Thankyou for finishing out the list InjectedSS
Old Sep 17, 2003 | 08:26 PM
hvyss's Avatar
If the car is pre 96 it came with green antifreeze. And yes there are terrible things about Dexcool. Heatercore plugging and eating freeze plugs to name a few. I drained and flushed all the Dexcool out of my 96 Impala ss and have been using Prestone green now for 4 years with no problems. Dexcool clogged my heater core. Good luck
HVY SS
Old Sep 17, 2003 | 08:43 PM
gb95zconv's Avatar
If you dont allready have them you may want to get some new head bolts....get some thread sealer too for the intake and head bolts. You want need the antisieze on anything other than the plugs so I belive you can take 1 gallon back
Old Sep 17, 2003 | 08:53 PM
S.J.S.'s Avatar
What exactly is antiseize and what is it used on?
Old Sep 17, 2003 | 10:13 PM
carlos64030's Avatar
There are 4 seals on the coolant tubes that are on the back of the heads that you should replace, crank seal, opti seal, water pump gaskets, and the driven gear seal.
Old Sep 18, 2003 | 01:26 AM
Van5150's Avatar
Thread Sealer is used on my Head Bolts\ Intake Bolts and Exhaust Bolts ? Anti sieze is only used on my spark plugs.
Is this correct ?
Old Sep 18, 2003 | 01:36 AM
Van5150...there isn't a need to put thread sealer on the exhaust bolts.
Old Sep 18, 2003 | 07:58 PM
gb95zconv's Avatar
Is this correct ?
Exhaust bolts dont need anything...yes to the rest. Get the seal and gaskets carlos refered to also. Also if you get the stock replacement headbolts they will allready have sealer on them.
crazypurgatory
Jan 12, 2015 10:45 PM
rs91
Aug 13, 2002 12:09 PM
Mad_Ice
Jul 29, 2002 09:44 PM
blue89iroc
Jul 26, 2002 04:56 PM
Manaz101
Jul 18, 2002 09:39 AM
