Rattle under the car, know the problem need a cure.
Old Jul 18, 2005 | 03:36 AM
'94 Bad A Z28's Avatar
Question Rattle under the car, know the problem need a cure.
The rattle is comming from my Pace Setter Y-Pipe hitting the floorboard under the driverseat. The y-pipe is formed with an indentation where the little piece comes down about an inch from the chasis and back up. Y-pipe fits perfect but still rattles against the floorboard.
Any ideas on what to do to stop this from happening? It knocks hard enough to set of my LT-4 KM sometimes.
Old Jul 18, 2005 | 09:54 AM
GreenZLT1's Avatar
Re: Rattle under the car, know the problem need a cure.
I had the same problem. I took some heat tape and rolled it up and wedged it between the floor and the y-pipe. I don't like the idea of doing that but it works.
Rob
Old Jul 18, 2005 | 10:05 AM
I was thinking about something like that, I'll give it a try. Thanks.
Old Jul 18, 2005 | 10:18 AM
nonojoe66's Avatar
yea mine does it too when i floor it, even after i took it off and re-shaped the indent on the y pipe 3 times. i took a piece of rubber heater hose and wedged it in there, but the tape idea is probably better
Old Jul 18, 2005 | 05:39 PM
Crazy95Z's Avatar
New motor mounts usually fix this problem.
Old Jul 18, 2005 | 05:52 PM
jchevy's Avatar
yep. Replace the motormounts. Fixed it for me.
jayblev95
Dec 1, 2014 06:55 AM
USAirman93
Nov 24, 2014 03:37 PM
squarehead
Nov 21, 2014 08:02 PM
Christopher
Sep 14, 2002 03:08 AM
Klypto
Jul 19, 2002 07:25 AM
