rattle, rattle, squeak, squeak, squeak...make it stop!
Old Nov 26, 2003 | 03:43 PM
pardonme2711's Avatar
i have this constant squeak/rattle sound that is over my head and to the left by where the window and the t-top meets it seems. its less squeaky when the t-tops are off. and its always less squeaky somtimes depending on how i put the t-top on. can anyone tell me how to kill this squeak?
Old Nov 26, 2003 | 03:47 PM
teke184's Avatar
a quick fix attempt would be some lithium grease or something to lube the contact points between the ttops and the weather strip.
it could also be body flex which is VERY common with ttop cars.
the only way to reduce (tough to really eliminate it) is some subframe connectors
Old Nov 26, 2003 | 04:03 PM
camaro 22's Avatar
I agree. SFC's should help, along with maybe a strut tower brace.
Old Nov 26, 2003 | 04:05 PM
aight great, thanks for the help. what are the best SFC to get and where can i get them at?
Old Nov 26, 2003 | 04:06 PM
camaro 22's Avatar
Also, if it's your t-top itself rattling, I know on my old 3rd gen, mine rattled and found out you could adjust the lock to make it a tighter fit. I don't know about the 4th gens though cause I have a vert.
Old Nov 26, 2003 | 04:10 PM
camaro 22's Avatar
There's a few companies out there. I have BMR. I think alot of people have them cause they're a little cheaper in price, and you have the choice of bolt in, or weld in styles. I think the weld in are better though. Any camaro sponsor has them like thunderracing.com. I bought mine from BMR themselves. Their site is BMRfabrication.com Good Luck
Old Nov 26, 2003 | 04:43 PM
if i get the weld in and dont know how to weld myself, will most perfromance shops do it for me?
Old Nov 26, 2003 | 05:23 PM
Janny's Avatar
If it is a fairly heavy sounding clunk from that area, it might be your shoulder belt slack adjuster. Mine makes some noise too. Not sure how to fix it.
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
4586
Sep 27, 2015 01:55 PM
KYWes
Sep 26, 2015 08:49 AM
autoxr166
Sep 25, 2015 04:21 PM
mark0006
Sep 14, 2015 12:35 PM
