ran into a little problem pics inside
Old Jan 8, 2004 | 09:26 PM
1FASASZ's Avatar
manifold bolt manifold bolt 2
so anybody know how i can remove this?
Old Jan 8, 2004 | 09:30 PM
jchevy's Avatar
Pics arent coming up.
Old Jan 8, 2004 | 09:42 PM
1FASASZ's Avatar
i dont know why they come jup for me
Old Jan 8, 2004 | 09:48 PM
mr_camaro96z28's Avatar
i cant get pics either but if you can tell us something like broke bolt or whatever maybe we can help.
Old Jan 8, 2004 | 09:53 PM
1FASASZ's Avatar
i broke a intake manifold bolt off in the head. its sticking up about an inch
Old Jan 8, 2004 | 09:55 PM
1FASASZ's Avatar
is the pic working for anyone?
Old Jan 8, 2004 | 09:56 PM
jchevy's Avatar
If its sticking up, grab a pair of vise grips and twist it out. Or if there is enough threads put two nuts on it and tighten them togethere and then unscrew it using the bottom nut.
Old Jan 8, 2004 | 09:57 PM
RENE95Z's Avatar
If you click on the link and drag your cursor down to the little earth looking icon in the bottom toolbar, it will load up the pic for you. Btw, good luck getting that out.
Old Jan 8, 2004 | 10:02 PM
jchevy's Avatar
Get some vise grips and clamp down on the **** as hard as you can and unscrew it.
I got the link to work. Had to copy and paste.
Old Jan 8, 2004 | 11:53 PM
You might want to use some penetrant on it like PB Blaster and then use a removal tool if the vice grips don't work. Sears has several tools for removal of broken bolts when there is something to grab.
Old Jan 12, 2004 | 09:20 AM
Try screwing a nut onto the bolt and tac welding in on then use a wrench or ratchet and pull out if that dosen't work you'll have to drill out the hole and retap it.
Old Jan 12, 2004 | 10:09 AM
Victory Racing's Avatar
This is a simple fix, and yes I have done it before. No welding or any of hat stuff required.
1) Spray the bolt down with PB Blaster or some like pentrant.
2) Take two nuts and spin them onto the bolt, I can see the pics and you have enough thred to get the job done.
3) Use a box/open end wrench and loosen the bolt by working the button of the two nuts.
4) It will work, and buy ARP hardare next time
Old Jan 12, 2004 | 10:34 PM
1FASASZ's Avatar
thanks for the reply but its to late im already sending them to Lioyd to have them ported
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
rjc1629
Jan 27, 2015 10:46 AM
Queens94z28
Dec 20, 2014 09:11 PM
omarECD
Aug 19, 2002 07:28 AM
