Ram air or cold air?
Old Mar 23, 2006 | 11:47 AM
BloodshotLt1's Avatar
I have a 95 LT1 T/A with a factory ram air hood I believe from a 97 as it was on the car when I bought it so not sure. I would like to make this ram air hood functional if not to expensive. would I be better off doing a cold air setup or making ram air work. Which will gain me more HP? where is a good place to get the parts. Any opinions are appreciated
Old Mar 23, 2006 | 11:57 AM
HardcoreRM125's Avatar
Re: Ram air or cold air?
Their assumed to be about equal. A cold air is a little less "in the way". And to make it functional you would need the tubing, and a good filter. I wuold imagine it would cost the same as a LPE CAI (160$) and perform about the same. A while ago people were taking the baffels out of them so thats something to keep in mind to do?
Old Mar 23, 2006 | 01:21 PM
97FormulaWS-6's Avatar
Depends on if you can find a deal on an airbox. If the hood is fully functional, all you need is the airbox, filter, and a pair of Fernco couplers to joint the Airbox/MAF/TB.
Old Mar 23, 2006 | 01:57 PM
LiENUS's Avatar
Theoretically a ram air intake is a little better than a CAI due to the straighter intake tract. supposably its a little better tuned
Old Mar 23, 2006 | 02:26 PM
Personally I think it's better CAI than a aftermarket CAI; ignoring the supossed RA effects.
I've got a completely de-baffled hood, and most of the loovers removed off the airbox. If I remove the airfilter, close the hood, and look through the openings.... I can see my TB blades... can't get much better than that.
Old Mar 23, 2006 | 10:41 PM
The picture of the ones I seen from SS Camaros sure werent as free flowing. They were definatly not a straight design, The scoop was back to far on the hood so they kinda looped back to the front.
Tommorow or Saturday Ill post a pic if anyone wants to see what I mean.
This can also be seen in the Feb 06' issue of GM High Tech Performance where they have a 10th Aniversary article with a 96 Camaro SS and a Mustang Cobra. On the other side of things, TA's look like their scoop may be mounted clkoser to the front explaining the straight through design.
Old Mar 24, 2006 | 01:02 AM
well call me an idiot with these forums but I have no clue how to post a picture or I would post one of my car. on the other hand I would like to see pics of your car ( 97 formula ws-6) because like I said I believe it is a 97 hood so I should be able to get some ideal of what I am looking for.
BTW thanks for the help fellas.
Old Mar 24, 2006 | 07:12 AM
I'll post some pictures of the hood and some archive pictures tonite; the car is dis-assembled for a major upgrade right now.
As for HardcoreRM125's comments; the SS ram-air intake setup is VERY different than the WS6 setup witha complete 360* turn in the intake track Vs the WS6 which is a straight-shot into the Throttlebody.
Old Mar 24, 2006 | 12:00 PM
Air box mods:
Fernco sewer pipe connector:
Debaffled hood scoop:
Old Mar 24, 2006 | 01:05 PM
Wow they do look WAY better than te SS's .... I seen the SS one in the magazine and it almost looked like a cold air tube bolted on sideways with more of a ben d to it. I was like WTF is that ???
Old Mar 24, 2006 | 07:10 PM
Great Pics man, the fernco fitting I am assuming is a 4" for joining clay or cast iron to pvc? besides that what other parts will I need to make that work? and do you know where I can get them? I also assume that this is on a 94 since that is your sig, what year is the Airbox assembly or does it matter?
Once again thanks for the great help
Old Mar 24, 2006 | 07:15 PM
Doug 97SS's Avatar
THe WS6 style like what Fred (Injuneer) has on his car is WAY better then the Camaro SS design. I got into a debate years ago over this and by switching to Cold Air I ran two tenths quicker in my 97 Camaro SS.
I say go for it.
Old Mar 25, 2006 | 07:12 AM
ChrisUlrich's Avatar
Originally Posted by Injuneer
Air box mods:
How safe is it to run a debaffled hood scoop everyday?
Are those two metal bars going across the air box?
Old Mar 25, 2006 | 07:18 AM
NVetro's Avatar
Chris, I dont think Injuneer runs his car everyday, espeicaly not in the rain. As for the 2 rods, when you cut the plastic "grill" off ur ws6 ram air box for more air flow, ya know the one that says ws6 and has a whole bunch of slots that restrict air to the actual intake box, lol. Yes those 2 bars are to hold it together and stop it from colapsing, keeps it rigid.
Old Mar 25, 2006 | 07:40 AM
I wouldn't run a completely de-baffled car everyday, but you can remove some of the baffles and still be ok.
The metal bars are what was described, to re-inforce the box because the entire center was removed.
The Fernco couplers you can get at any local hardware store for about $5 a piece. You need the 3" ones, and boil them in water for a minute or 2 to soften them up, then install them.
I run a full one between the TB and MAF, and one cut in half between the Airbox and MAF.
