Ram Air Airbox--cut out the vanes?
Old Aug 9, 2003 | 11:52 AM
Kuma's Avatar
Question Ram Air Airbox--cut out the vanes?
Here's a question for you guys running the ws6 style ram air airbox. Would cutting out the vanes on the front improve airflow? The seem pretty constrictive, covering about half the surface area of the air filter. Would it make any difference? Or should I leave mine stock? I've seen pics of engines where the air filter is totally exposed and it looks cool.
Thanks,
Rob
Old Aug 9, 2003 | 12:02 PM
AsianSensation's Avatar
A buddy on mines did. He swore it made a difference...at least in a sucking sound. See pic.
Modified WS6 box
Old Aug 9, 2003 | 01:16 PM
Josh-'04 GTO's Avatar
I cut mine out as well, but it was part of a round of things I did so I didn't have a back to back comparison.
Old Aug 9, 2003 | 04:02 PM
john96ws6's Avatar
I cant imagine it making much of a difference. Its like taking the screen off your MAF sensor, its just one of those things you do when your bored.
Old Aug 9, 2003 | 04:06 PM
craigffb's Avatar
I wouldn't cut it. It will make the top of the box weak. I left mine alone, can't see it making much difference.
Old Aug 9, 2003 | 04:38 PM
97FormulaWS-6's Avatar
I have mine trimmed... some bars are removed, others were left... don't know about the airflow.. although I would believe it may help somewhat.. even though the fins direct the airflow through the filter instead of then having to bounce off the back of the airbox/seal...
Originally posted by craigffb
[B]I wouldn't cut it. It will make the top of the box weak. /B]
Actually, it doesn't. I've taken the top part off many times to maintain the filter and it's fine.
Old Aug 9, 2003 | 04:41 PM
craigffb's Avatar
That's cool. I thought it would. But like 97FormulaWS-6, if you look, the fins do direct the airflow across the top of the filter.
Old Aug 9, 2003 | 08:11 PM
Kuma's Avatar
I've seen guys in magazines do it with an airbox that looks different from the ws6 one...most of them were running high performance rigs.
I'm wondering though...the air filter has got to be one of the less restrictive parts of the intake system. Following the logic of, for example, the heads, where grinding out the intake ports doesn't do so much since they already flow well, maybe it wouldn't make much of a difference? Could it even perhaps slow down the air going in, resulting in a slight torque loss? Any engineers want to chime in?
Old Aug 9, 2003 | 10:38 PM
sc1twntrbo's Avatar
dotn know if this helps but i got as buddy who dynoed his car. and then took the filter otu completely and gained 1 hp. so hearing this i figure the stock air box the way it is shoudl be ok
F'n1996Z28SS
Aug 23, 2023 11:19 PM
LT14LIFE
Feb 9, 2015 09:35 PM
rjc1629
Jan 27, 2015 10:46 AM
TitoPR221
Parts Wanted
Jan 10, 2015 09:21 AM
