Anyone using Metco Adj. Fuel Pressure Reg. Kit?
I was wondering if anyone is using the Metco Adjustable Fuel Pressure Regulator conversion kit? Does it work ok? Any problems with it? My fuel pressure is a little low on my TA (45.5lbs with vac line off). I found out it is running pretty lean and with the mods I have I assume I need to bump up my pressure a bit. So I just wanted some feed back on the Metco product!!
Thanks!
Thanks!
Wilson
Jul 21, 2002 05:08 PM
