raiator has a hole!!!!help..help..
Old Oct 7, 2005 | 01:44 PM
CHELOZ28's Avatar
I was driving to work when I noticed my temp rising, I was only only a couple blocks away so I figured I should get there with no problem. Well I parked and then all of sudden I heard hissing noise I pop the hood, and there was coolant shooting out of my radiator , it is a very small hole next by the battery . I have a couple of questions, What would be the best way to get it back home, I live about 10 mins away..can I use some kind of sealant?. I looked online and I found a place that has them in stock(radiator) for $150.00, is this about right? One more question, is this a easy install, or does anyone have a link to a guide? Also money is very short.....Please help anyone .
Old Oct 7, 2005 | 02:12 PM
walt355's Avatar
Re: raiator has a hole!!!!help..help..
ID fill it full of Water and see how bad it is. The way you described the tank has a crack in it. IF thats the case than it should make it. It might have been leaking a while. Also(Not sure on an LT1) but on an old set up you could leave the toploose where the system wouldnt built up pressure. This will slow or stop the leak. Good luck
Old Oct 7, 2005 | 02:53 PM
CHELOZ28's Avatar
okay thanks for the input guys, I will use that sealer and get it home.
Old Oct 7, 2005 | 03:01 PM
69gto96z's Avatar
Just build it up over the hold with some JB-kwik. Get the quick version because it hardesn in under 10 minutes where as regular JB-weld takes overnight I think.
Old Oct 8, 2005 | 07:37 PM
CHELOZ28's Avatar
Hay guess, I replace my new radiator, but know my low coolant sensor is leaking, is there any quick fix to this? Or do I need to purchase a new? It works good as my light never turns on. Please help sun is almost down, and I have to go out with my gf, helP!!!!!!!!!!!!
Old Oct 8, 2005 | 10:07 PM
Dave89IROC's Avatar
the low coolant sensor is sealed with an oring, so, replace the oring
G-BODYT56
Jan 14, 2022 11:14 PM
drt
Sep 27, 2015 04:39 PM
generaldave
Sep 25, 2015 06:48 PM
4586
Jul 31, 2015 06:03 PM
Boss002
Jul 24, 2015 10:47 AM
