Radiator Replacement
Old Oct 24, 2004 | 12:45 PM
BoobSter-lt1-z's Avatar
ALRIGHT...WELL AFTER POURING IN COOLANT EVERY 4 DAYS I DECIDED TO
CHECK IF THERE WAS A LEAK AND THERE WAS. I FOUND A LEAK 4" BELOW THE RADIATOR FILL NECK. MY QUESTION IS, IS IT AS EASY AS REMOVING THE HOSES, TAKING OUT THE RADIATOR, PUTTING THE NEW RADIATOR IN AND PLUGGING THE HOSES BACK IN ??? WHAT KIND OF RADIATOR WOULD YOU SUGGEST (MOST BANG FOR BUCK) ????..... I AM THINKING OF PURCHASING THIS RADIATOR ON THURSDAY (28TH OCTO) AND INSTALLING IT THAT WEEKEND.....
THANKS FOR THE INPUT.
Old Oct 24, 2004 | 12:51 PM
lillbush5555's Avatar
Re: Radiator Replacement
Get a stocker There pretty cheap
Matt
Old Oct 24, 2004 | 12:52 PM
ShawnMacAnanny's Avatar
Everyone who has done a cam swap has removed their radiator and hoses and put them back it. It's not that hard. I would also say go with a stocker.
Old Oct 24, 2004 | 01:40 PM
Now The Other Radiator Look Alike Thing In Front Of The Radiator
Is The Ac Condenser Coil Right????
Old Oct 24, 2004 | 01:50 PM
texas_z28_guy30's Avatar
yes it is the condenser
Old Oct 24, 2004 | 03:52 PM
hOW LONG WOULD THIS TAKE...APPROXIMATELY...2HRS?
Old Oct 24, 2004 | 03:54 PM
Are There Any Other Fluid Lines That Run In This Radiator...i.e. Transmission Fluid? Or Is It Just Coolant?
Old Oct 24, 2004 | 03:58 PM
CamaroBoy96Z28's Avatar
6-speed or auto car? I took my radiator out in under an hour and could easily swap a radiator in under 2 hours start to finish, staying focused. Get another stocker, I had a crack in mine and got one off the board for $75 shipped a few months back.
Magenta_Hearts
Mar 29, 2017 08:54 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Jazsun
Dec 29, 2014 12:14 PM
