Radiator question
Old Oct 8, 2003 | 10:54 PM
CeeBee94Z's Avatar
Radiator question
I have a question guys....you know that black plastic piece on the side of our radiators(the filler for the radiator itself, not the overflow) is that replacable? I have a crack going down the back side of it so it leaks out of there. Is it worth replacing just that piece or should I replace the whole radiator?
Thanks guys
Old Oct 8, 2003 | 11:08 PM
madwolf's Avatar
Looks like you can replace just that one part.
Part number: 52465338 for your car.
$22+shipping at gmpartsdirect, probably cheaper through Jason Cromer. Just make sure that's what's really leaking before you order.
Old Oct 8, 2003 | 11:11 PM
madwolf's Avatar
Oh yes, forgot to mention. You'll probably want a new gasket for it as well.
PN: 52484143
Old Oct 8, 2003 | 11:19 PM
CeeBee94Z's Avatar
Awesome, thanks
Yes it is definitely leaking, I had the car running and saw it spewing out of the plastic piece, plus I could see the crack going down it too.
Thanks again, thats much cheaper than a new radiator
Old Oct 8, 2003 | 11:23 PM
madwolf's Avatar
Originally posted by CeeBee94Z
Awesome, thanks
Yep, cheaper than a used radiator too.
Old Oct 8, 2003 | 11:26 PM
CeeBee94Z's Avatar
Do you have a pic of what you are talking about so I can make sure it is the same thing that I am talking about?
Also, I noticed that it says it can only ship to a business address...would that be a problem?
Old Oct 8, 2003 | 11:33 PM
madwolf's Avatar
Certainly.
Check it out here.
Jason will most likely ship it to you.
Old Oct 8, 2003 | 11:46 PM
CeeBee94Z's Avatar
Certainly.
Check it out here.
Cool deal, do you know how easy it is to replace that? Or should I have someone else do it so it is done correctly?
Thanks for the help
Old Oct 8, 2003 | 11:48 PM
madwolf's Avatar
Sorry, I don't know. Never had to do that on my cars, YET.
I'm sure someone else will give you more advice on replacing it though.
Also, while the radiator is out, might as well flush it real well....
Old Oct 10, 2003 | 01:38 AM
CeeBee94Z's Avatar
Anyone know how easy it is to replace just that piece and the gasket? Is it worth my time or should I have someone else do it.
Thanks guys
calaban
May 18, 2020 06:43 PM
Magenta_Hearts
Mar 29, 2017 08:54 PM
grgguy
17
Feb 23, 2015 07:57 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
