Radiator Fan Issues
Old Aug 15, 2006 | 06:30 PM
matLT1's Avatar
Radiator Fan Issues
I'm having an issue with one of my fan motors. The problem is that the drivers side is not running but the passenger side is. I figured it was the motor fried so I got a new one, but that didn't fix it. I did a little reading on shoebox's web site that said the late 94's (thats what mine is) had a three relay system. However mine only has two there (maybe it's just the two relay style..) Does that seem like a possibility? If so, how do you test them?
Matt
UPDATE:
I swapped different relays around in an attempt to see if that was the issue. Seeing as though I know my fog lights and secondary fan work, I used those relays too test the primary fan but neither made it come on. I also checked the fuse. Any other ideas? Thanks
Old Aug 15, 2006 | 10:05 PM
Re: Radiator Fan Issues
Check to see if power and ground is getting to the fan when the relay is engergized.
calaban
May 18, 2020 06:43 PM
Magenta_Hearts
Mar 29, 2017 08:54 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
MattFick
Feb 15, 2015 10:16 PM
4586
Dec 31, 2014 02:21 PM
