Radiator drain valve stuck!
Old Feb 13, 2005 | 03:12 PM
whiTetAlt1's Avatar
I worked on it for about 30 min and I couldn't get it to budge. how can I get that bastard to turn?
Old Feb 13, 2005 | 04:10 PM
madwolf's Avatar
Re: Radiator drain valve stuck!
I broke both ears on mine and ended up heating it up with a propane torch and removing it with some pliers. The downside is you will need a new one, but you'll probably brake your old one anyway taking it out. The new ones are cheap and they come in packs of 5 or 10 if I remember correctly. I got a few of them left in my garage.
You can also try heating it up just a bit, without melting it.
Old Feb 13, 2005 | 04:11 PM
GreenDemon's Avatar
30 minutes?! I didn't know that little piece of plastic would hold up to that much. Just get some needlenose pliers, get a good grip, and turn. It will either start to move or you'll just get the end of it in your hands and have to drill the rest out.
Old Feb 13, 2005 | 04:13 PM
30AnvZ28's Avatar
I used channel locks, broke it, and then bought 1 from auto zone for like 99 cents.
Old Feb 13, 2005 | 06:00 PM
whiTetAlt1's Avatar
got it! i heated it up and used some pliers and it didnt end up breaking! thanks yall
Magenta_Hearts
Mar 29, 2017 08:54 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Sandersen511
Jan 13, 2015 03:49 PM
Jazsun
Dec 29, 2014 12:14 PM
