racing fuel? yes or no
I was wondering if you can run race fuel in a fuel injected car. I know it plugs the cat, but what about fuel injectors? I have aftermarket inj's the motoron 60#'s and no cats. thanks
96 formula LT1 Vortech s/c, 7#'s, Hooker LT's, Magna flow cat back, th-350
4.10, pcm4less tune, MT drag radials.
Re: racing fuel? yes or no
I'm still looking for the elusive 110-octane ( (R+M)/2 ) unleaded. The most I have found is 105 (VP Fuels Motorsport 109). Some people confuse the VP Fuel C10 with 110-octane, but its only 100.
http://www.vpracingfuels.com/vp_01_fuels.html#unleaded
http://www.racegas.com/fuelspecs/default.asp
Originally Posted by atljar
You have to average the numbers. You have (91+91+91+91+110)/5 = 94.8 octane.
As for 1 gallon of leaded fuel... Thats plenty to screw up your o2s.
Does anyone make lead proof o2s? The reason I ask is just because mine have 120K on them and I am sure they will bight the dust anytime. Probably inaccurate as it is.
Don't sweat it unless you plan on running 110-112 leaded daily. Every time I run my car on n2o I put 5gallons of 110 or C12 whatever is available and mix it with about, less than 1/4 tank, 2-3galls of 93 already in the tank. I have changed 02 sensors once b/c I thought they were bad but it was something else. I run 200HP n2o with full timing and the above mixtures with great results, look at sig for details. Once I get home I go and put about 8-10galls of 93 and everything is fine. Later Clint
This is from 1 of the sites sponsors.
mixing 4 gallons of 91 unleaded with one gallon of 110 does NOT equal 94.8 octane because one cannot do a simple add the 5 gallons & average them with leaded fuel being in the mix. It has a synergistic effect toward boosting octane. That's the reason why back up til the late 80's one could mix 89 octane LEADED regular with 92/93 octane unleaded and actually get 95 octane fuel. The actual octane of this proposed mix would probably be around 98+ octane. Get lead resistant O2 sensors from NGK or Denso & you will be good to go for leaded on the weekends and no-lead during the week.
The way that the octane system was devised is based on the fact that some hydrocarbons burn more "smoothly" than others. Heptane which is a linear chain with 7 carbon atoms has a 0 octane rating because it reacts violently when burned and can combust without spark if it is compressed enough. 2,2,4-Trimethylpentane is a 8 carbon (octane) branched chain molecule. That is the "ideal" automotive fuel with a 100 octane rating. For the octane inbetween, for example 87 octane, are rated by their performance in relation to those two molecules. 87 octane performs similarly to a mixture composed of 87% 2,2,4-Trimethylpentane and 13% n-Heptane.
For octane ratings over 100 I don't know how it works... What is the (R+M/2) method? I never learned what that meant...
I did a bit of research last year and made a few calls and there is nowhere near a substantial amount of lead in these fuels needed to screw up an o2 sensor. its like .05 percent or something
