Racing Fuel Hurt stock engine?
Old Jul 22, 2007 | 11:14 AM
CamaroRacing12's Avatar
I have a stock 350 LT1 with some bolt ons... racing fuel is a higher octane.... will it hurtmy engine to run that fuel frequently? i want to learn as much as i can so any input would be much appreciated... thx guys
tony
Old Jul 22, 2007 | 11:22 AM
There is no technical specification for "racing fuel". What exactly are you planning to run? Excessively high octane unleaded fuel will neither help or harm your engine, as long as you aren't getting knock on the recommend octane pump fuel. Leaded high octane fuel can contaminate the O2 sensors over time, and poison the catalytic converter.
Old Jul 22, 2007 | 12:00 PM
Built LT1's Avatar
You might want to post this in the advanced tech section as the question could pertain to any engine. I've actually heard of this happening, but I don't know if that is factually true.
Old Jul 22, 2007 | 12:27 PM
96ZCamaro's Avatar
Well it will probly not gain you any power at all unless you change the fuel and timeing tables to go with it.
Old Jul 22, 2007 | 12:32 PM
truedualws6's Avatar
I run about 3 gallons of 100 unleaded in each tank of gas to try and
offset the crappy CA 91 octane premium fuel. The car loves it and the
only downside is the cost.
Old Jul 22, 2007 | 08:53 PM
i run 93 octane never anything less.... but i was wondering would 100 octane help or hurtt he engine?
Old Jul 23, 2007 | 08:35 AM
Not sure how to state it any more clearly than that.
Old Jul 23, 2007 | 08:41 AM
immortalmack's Avatar
I remember 102-107 octane Sunoco running in everyday cars in the 80's so you should be fine.
Old Jul 23, 2007 | 08:49 AM
1SlowFormula's Avatar
On a few occasions, I have run the car down pretty low at the track, and had to get the lowest octane they had on tap and it was 110. There were no performance differences and no damage, but then again I haven't had a cat on this car for more then 6 years, and my O2's looked/worked OK when I swapped out them out doing headers last year...
Old Jul 24, 2007 | 06:23 PM
so no performance differences? so wy do peple run higher octane then say 93?
Old Jul 24, 2007 | 06:39 PM
96z28t56's Avatar
some people need the higher octane for higher comperssion ratios. 11 to 1 is about the limit for 93 on the street. People with say 13 to 1 engines would need the higher octane to prevent knocking, pre-det... ect
oldschool
Feb 9, 2016 09:21 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
Catmaigne
Dec 25, 2014 12:16 PM
thenewkid
Nov 27, 2014 09:41 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
