Racetronix walbro 255 w booster
Old Jun 19, 2011 | 04:11 AM
96LT1TX's Avatar
What is the HP limit of this pump? I bought it and had it installed thinking around 600rwhp was the limit but just wanted to double check before I re-jet the nitrous. Anyone have experience maxing it out? I am at 500rwhp/636 rwtq with the 100 shot; would love to rejet for a 200shot
Old Jun 19, 2011 | 07:38 AM
Kevin Blown 95 TA's Avatar
Re: Racetronix walbro 255 w booster
I don't know if anyone can guarantee that for you. Hopefully, you have a fuel pressure safety switch, in case you try it out and don't have enough. A lot of us started running two pumps around that power level. Sounds like you have a nice setup.
Old Jun 19, 2011 | 09:29 AM
You need to start with the flywheel HP, not the rear wheel. Appears you have an M6, so you are looking at about 700HP at the flywheel. If you assume an 0.55 BSFC due to the nitrous, and allow for a 20% recycle to the tank for safety, I calculate you are looking at about 305 LPH. With a lower BSFC and a lower recycle, you might just make it.... but I wouldn't put my money on "might".
I'm running dual 205 LPH (410 LPH total) high pressure pumps, for 800HP at the flywheel, with a 300-shot). The second pump only operates when the nitrous system is armed.
Old Jun 19, 2011 | 09:45 PM
96LT1TX's Avatar
Ya, sounds like the 200shot may be where I need the upgrade. 150shot sounds like it is still possible though safely. I should probably install a permanent fuel pressure gauge for this setup...
Quickss96
Jan 29, 2016 05:56 PM
form94
Sep 23, 2015 07:30 AM
95craz28
11
Sep 12, 2015 07:47 AM
alphaauto
Jul 26, 2015 04:40 PM
mrwz28
Jul 8, 2015 09:11 PM
