How to improve my LT1
Old Jun 19, 2011 | 08:50 PM
TheKrustinator's Avatar
I am a fairly new Camaro owner (97 Z28) and plan on doing an engine swap in two or three years. Until then, though, I would like any tips on improving my LT1 engine while staying under a $2,000 budget. I'm not much of a car guy, but would like to start learning on my own vehicle. Again, any tips would help, thanks.
Old Jun 19, 2011 | 09:27 PM
Re: How to improve my LT1
Cold air intake, catback exhaust or duals, headers, throttle body coolant bypass, 1.6X full roller rockers, more aggressive camshaft.
Is the trans automatic or manual? If automatic, which rear axle ratio does it have?
Old Jun 19, 2011 | 10:01 PM
It's stock everything with an automatic, so whatever came stock with the 97 Z28 model. Also, what brand of catback should I get, I know Flowmaster is American, but I also know it's more expensive than Magnaflow and the Magnaflow is stainless steel.
Old Jun 19, 2011 | 10:05 PM
You could get either a 6-speed manual trans, or a 4-speed automatic trans with either 2.73 (RPO code "GU2") or 3.23 ("GU5") rear axle. Which one do you have? Axle codes are on the build code tag in the glove box.
With an automatic, a higher stall torque converter and a set of 3.73 gears will really wake it up. With a manual trans, consider 4.10 rear gears.
Old Jun 19, 2011 | 10:16 PM
30th97z's Avatar
Originally Posted by TheKrustinator
It's stock everything, so whatever came stock with the 97 Z28 model. Also, what brand of catback should I get, I know Flowmaster is American, but I also know it's more expensive than Magnaflow and the Magnaflow is stainless steel.
Go with the Magnaflow cat back system because it sounds GREAT on the LT1 car's!!!!
Jul 4, 2005 05:00 PM
RichJ
Sep 26, 2002 09:43 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
Timberwolf
Aug 18, 2002 07:39 PM
ferraricameron
Jul 29, 2002 07:46 PM
