Racetronix Install Question
Old Sep 24, 2004 | 05:24 PM
  #16
Racetronix's Avatar
Re: Racetronix Install Question
Originally Posted by 96lt1Camaro
Little bigger gauge wire. Not welded but crimped together tehn tape was wraped around it.
Tape will dissolve in the gas and make a mess.
A nylon (NOT VINYL) butt connector MUST be used.
Teflon wire must be used not plastic / PVC.
Old Sep 24, 2004 | 06:32 PM
  #17
96lt1Camaro's Avatar
Good to know, Its all thumbs up except for the tape, ill change that asap.
Old Sep 24, 2004 | 08:05 PM
  #18
Can i use a non insulated butt connector? or does it need to be insulated, or vinyl like you said?
Old Sep 24, 2004 | 09:41 PM
  #19
Spinner's Avatar
Solder it
Old Sep 25, 2004 | 03:27 AM
  #20
Racetronix's Avatar
Two options using Teflon wire only.
solder w/ teflon heatshrink
nylon butt connector (not vinyl)
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
nautilus
Aug 22, 2002 11:49 PM
Chrisdude
Jul 24, 2002 02:25 PM
