Racetronics dual pump system ....?
Old May 17, 2003 | 03:53 PM
385LT1's Avatar
i have heard rumors that this system will support 700 rhwp through stock lines.....
true / false ?
i didnt see the dual pump setup on their website....
I am prepared to go the aeromotive route with my custom fuel system.
but $400 is better than $1500 any way you slice the pie..... if their system can cut the mustard......
thanks...
Old May 17, 2003 | 05:04 PM
385LT1's Avatar
ttt
Old May 17, 2003 | 06:49 PM
Zepher's Avatar
Hey Scott,
could you possibly run 2 Walbro pumps in the tank?
That would be about $300 then just mod the feed line that comes out of the tank and put an 8an 90* fitting onto the top of the tank.
Old May 17, 2003 | 08:04 PM
385LT1's Avatar
Thats what racetronics does, im pretty sure.... not sure about the AN fitting.
and not sure how their pump setup would fair with 8 or 10 AN supply line....
Im really swaying towards the aeromotive route, just because i know so many people with custom systems with large line... and have more than enough fuel.. I would rather have more than enough fuel than wonder if i will have enough.....
and if i have to change to larger diameter line, then im going aeromotive anyway.
Old May 19, 2003 | 06:24 AM
IDOXLR8's Avatar
My buddy runs 9's in his Grand National with a twin intank setup. He made a custom twin intank setup for my car so hopefully I will have some number pretty soon. I was running the Aeromotive setup and did not like it. I had a relay go bad and leave me stranded on the side of the road. If you are thinking about running a big single pump then I would recommend going with a Weldon pump.
Sergio
Jan 27, 2016 04:27 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
