R/R bearings in drivetrain??
Old Jul 1, 2003 | 04:54 PM
jwade95Z's Avatar
Started noticing moans and warbling sounds around corners ... checked for play in bearings, found passenger side rear moved slightly ... So, replaced axle bearings & seals this past weekend. Still have the noise ...
Any suggestions? What else could it be? This car only has 65K on it.
If the pinion bearing/seal is one option, is there an easy way to check?
Thanks.
Wade
1995 Z28, M6
Ericksd
Jan 20, 2016 06:07 PM
WobblySausage
Oct 7, 2015 02:44 PM
Bxlt1
Sep 29, 2015 03:18 PM
95craz28
11
Sep 12, 2015 07:47 AM
