quick wiring question
Old Nov 23, 2004 | 04:36 PM
sky0787's Avatar
Ok.. I just replaced the heater core in my hoopty (AKA 94 Z28) now for some reason when I turn the AC/heater on the air comes out of the floor boards. No matter what, no air will come out of the vents at any temperature. It's my thought that a wire is out somewhere... just not sure as to where. Anyone ever had this problem before? I swear... I should have just left it stock and boring... grrr
Thanks and if anyone can help me out on this, I'll buy them dinner
Old Nov 23, 2004 | 04:49 PM
americanmusscle's Avatar
Re: quick wiring question
Is there anything blocking the blower motor? Did you connect all the hoses and whatnot?
Old Nov 23, 2004 | 04:58 PM
Most likely you managed to pull loose the vacuum hose that powers the air doors in the heater/AC system.
Old Nov 25, 2004 | 03:56 PM
sky0787's Avatar
Which one is that? There are like 50 wires under my dashboard that I had to move out of the way to repplace the heater core.. no idea which on that is.
Old Nov 25, 2004 | 07:09 PM
There is a black hose that goes into a multi-hose connector with other colored hoses. That black hose coming from the engine compartment is the vacuum feed to the mode control on the dash.
Jan 23, 2015 01:13 PM
Jazsun
Dec 29, 2014 12:14 PM
lbrowne
Nov 13, 2011 04:25 PM
