Quick question about oil pan
Old Apr 13, 2004 | 10:37 AM
  #16
Red96Lt1's Avatar
Sweet, thanks. Do I have to worry about brake lines or anything like that?
Old Apr 13, 2004 | 10:41 AM
  #17
WS Sick's Avatar
No just loosen the 2 longest bolts on each side as far as they can go , then tighten them a few cranks to make sure they will hold, you should be fine.
Old Apr 13, 2004 | 11:13 AM
  #18
Red96Lt1's Avatar
cool, I'm guessing the bolts go vertical and the bolts will continue to hold the k member up. Thanks alot!
Old Apr 13, 2004 | 02:26 PM
  #19
WS Sick's Avatar
Yep, I just used the tallest jackstands I had positioned under the fron swaybar mounts on the frame, then I slid the jack under the K, loosened the Ks bolts let the jack down, unbolted the motor mounts and jacked up the engine.
Old Apr 13, 2004 | 02:38 PM
  #20
FormulaLT-1's Avatar
I'll be doing this shortly also, your not alone.
HectorM52
Jul 30, 2017 11:46 AM
94Form
Feb 10, 2015 11:23 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
Elcojoe
Nov 17, 2014 10:27 PM
