Quick question!
Old Mar 22, 2011 | 06:17 PM
350lt's Avatar
Quick question!
Can i use a '96 lt1 coil on '94 vette engine and '94 opti? Im using the original '96 z28 pcm.
Old Mar 22, 2011 | 06:43 PM
Kevin Blown 95 TA's Avatar
Re: Quick question!
The connectors are different - the 94 coil has a double connector with 4 wires, but the connections are redundant, If you had it in front of you, you could probably see what I'm talking about. And the 96 -97 has a single 3 pin connector. Not sure if there is a simple pigtail swap.
Also, you should probably use the 95 or later opti if you can, it's a better distributor.
Old Mar 22, 2011 | 09:11 PM
350lt's Avatar
Re: Quick question!
well i got both coils but i had to use the '96 coil becuse the '94 coil had a different connecter. im using the '96 harness. i was just wondering if i could use the '96 coil with the 94' opti.
alex5366
Feb 17, 2015 09:07 AM
94Form
Feb 10, 2015 11:23 PM
Jan 23, 2015 01:13 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
