quick plug question
Old Apr 3, 2005 | 08:34 PM
ericz28w's Avatar
quick plug question
ok, i have a 383 stroker, and will be spraying n2o to her, would u guys recamend tr55 or tr6. also are taylor 8mm wires a good choice for my set up.
thanks alot guys, i did a search but didnt find any direct answers
Old Apr 3, 2005 | 08:42 PM
ericz28w's Avatar
Re: quick plug question
opps one more question, what u guys think of thunder racing over the valve cover set up? worth spending 100 bucks
Old Apr 3, 2005 | 08:49 PM
Hyperspeed97z28's Avatar
tr6 is for you I believe.. I used to use the tr-55's, I didnt spray...
I'd say the over the valve cover kit is worth it
Old Apr 3, 2005 | 09:14 PM
94zgreenmachine's Avatar
Comes with everything. Crimping tool, lt 1 boots. I used the extra boots to practice the crimp. Very easy!
Old Apr 3, 2005 | 11:25 PM
ericz28w's Avatar
are any wires even close to your headers? do you have to sleve the wires?
Old Apr 4, 2005 | 04:44 AM
Not with the over -the-valve cover wire set.
Old Apr 4, 2005 | 01:53 PM
Plug choice depends to some extent on what kind of HP you are making with the 383 without the nitrous. You probably should have gone to the TR6 or an Autolite 104 just based on the higher HP output of the 383. Then another step colder for the nitrous, assuming you are only spraying 200 or less. I run Autolite 103's for street driving (~500HP plus a 125-shot).
94Form
Feb 10, 2015 11:23 PM
Jazsun
Dec 29, 2014 12:14 PM
cmdeshon
Dec 27, 2014 10:06 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
