Quick EGR Valve Question
Old Aug 24, 2004 | 11:16 PM
Loadre's Avatar
If the vacuum line and electrical connection are unplugged, would a bad EGR valve still cause the car to act up? EGR is blocked off, btw. Thanks.
Old Aug 24, 2004 | 11:21 PM
Re: Quick EGR Valve Question
If the valve is still in place and is not sealing, it can be a problem source.
Old Aug 25, 2004 | 09:35 AM
Loadre's Avatar
Thanks yet again. Time to go order one.
Old Aug 25, 2004 | 05:05 PM
You say your EGR is blocked off? I guess you mean the feed pipe? Why not just put a block-off plate in place of the EGR valve, then?
Old Aug 25, 2004 | 07:34 PM
Loadre's Avatar
Cause I don't like spending money buying things when I can fabricate them. We fabbed the EGR pipe blockoff while the motor was out and I just didn't think to do the valve as well. Know anywhere that has a template or do you think I could make one by tracing the outline of the EGR valve on some aluminum plate?
HectorM52
Jul 30, 2017 11:46 AM
97SSdude
Dec 31, 2014 07:43 PM
jocamino
Dec 29, 2014 10:15 PM
Jazsun
Dec 29, 2014 12:14 PM
