Quick ? for edelbrock 58mm users
Old Apr 1, 2006 | 11:37 AM
klpps's Avatar
There is a gray piece of foam sticking out from underneath the IAC. Is this normal?
Old Apr 1, 2006 | 11:44 AM
96capricemgr's Avatar
Re: Quick ? for edelbrock 58mm users
Can you post a pic?
I found it necessary to drill a IAC bypass hole in that TB. If you look low between the bores of the stocker above the IAC feed hole there is a small hole drilled, most aftermarkets do not have it drilled. Some people open the TB a bit with the throttle stop screw but that results in a less than perfect idle and can require some TPS adjustment. Drilling the hole works much better, just use a bit about the size of the stock hole.
Old Apr 1, 2006 | 11:58 AM
klpps's Avatar
http://www.shenger.net/misc/tb.JPG
http://www.shenger.net/misc/tb2.JPG
Old Apr 1, 2006 | 12:08 PM
That is a seal for the TPS and yes it is normal. The IAC is the one on bottom of the TB.
Old Apr 1, 2006 | 12:15 PM
klpps's Avatar
oops. thanks man i appreciate it.
dfarr67
Apr 10, 2015 07:44 PM
maybe2fast
Mar 26, 2015 08:34 AM
CARiD
Jan 27, 2015 06:27 AM
squinn
Aug 4, 2002 01:06 PM
