Quick connect for msd 6al
Old Jan 2, 2012 | 11:50 AM
z28_4life's Avatar
I need to order a quick connect harness for my msd 6al. I originally just cut/spliced the wiring harness in order to make it work but would like to clean up the wiring with the quick connect. Does anyone know where I could order one for my 94z28 on the cheap?
Old Jan 2, 2012 | 03:31 PM
Re: Quick connect for msd 6al
Some of the site sponsors would appreciate your business.
Old Jan 2, 2012 | 04:55 PM
z28_4life's Avatar
I gave Summit a call today to see if they could point me in the right direction. Apparently msd has discontinued the 6al so they don't have any of the part numbers in their computer data base. The tech told me if I had the instruction manual all I would need to do would be to grab the part numbers that I require and he could look them up from that. If only I would've spent the extra $25
8 years ago I could avoid this whole situation.
Old Jan 2, 2012 | 05:11 PM
8876 is the p/n for the dual connector coil harness.
Old Jan 2, 2012 | 05:29 PM
z28_4life's Avatar
Yep, I definately already have that (good news). I was trying to track down an electrical issue which turned out to be a defective msd opti (early model). Is the larger connector of the quick connect harness(2 dual prong) plug into the msd connector. If that's the case that's where my problem lies because I couldn't figure out where that portion went. Obviously the single two prong is going into the coil.
Drtryder
Apr 22, 2015 04:17 PM
thenewkid
Apr 12, 2015 07:42 PM
Killer94z
Jan 13, 2015 12:06 PM
thenewkid
Nov 27, 2014 09:41 AM
