Quick cam question
Old Apr 17, 2008 | 10:13 PM
96' Formula WS6's Avatar
Quick cam question
I am piecing together a cam only setup and have a quick question. I have been reccomended the Comp 224/230 cam from a friend and wanted to know if thats rated that with 1.5 rockers or 1.6. Also what would that make the I/E lift and duration with 1.6 and whats the formula you use to figure that out. Thanks
Heres the Link that I was shown for info on this cam.
http://www.thunderracing.com/catalog...&vid=4&pcid=51
Old Apr 17, 2008 | 10:34 PM
Stl94LT1's Avatar
The 502/510 lift is with 1.5 rockers.
Old Apr 17, 2008 | 10:57 PM
White96Z28's Avatar
Your rocker arm ratio is going to change the lift, not the actual duration of the cam... Although I guess you could argue that the duration at .050 would increase because of the change in lift...
Old Apr 17, 2008 | 11:04 PM
mdacton's Avatar
search for that cam used.....its popular
Old Apr 17, 2008 | 11:24 PM
ok guys i appreciate the help. but would going to 1.6 from 1.5 take 502/510 to 550.2/560. Not sure exactly how that works.
Old Apr 17, 2008 | 11:37 PM
Lift would be .536/.544 with 1.6 rockers.
You take your lift number and divide by 1.5, then take that result and multiply by 1.6.
I run the same cam, but on a 114 LSA.
Old Apr 18, 2008 | 12:25 AM
Ok thanks alot I really appreciate it. Im ready to get this project underway.
oldschool
Feb 9, 2016 09:21 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
