Questions....Please look
Old Jan 13, 2006 | 06:14 AM
blahster's Avatar
Exclamation Questions....Please look
Too lazy to search all these....lol
1. Stock Plug wires handle over 400rwhp?
2. Stock TB able to handle over 400rwhp?
3. Should i use NGK tr-55 or tr-6 for my 355 LE3?
Thanks!
Old Jan 13, 2006 | 10:26 AM
MyShibbyZ28's Avatar
Re: Questions....Please look
Thanks!
1. Yes, wires don't deliver horsepower, they just improve timing to it's max.
2. Yes, specially if it's got a blower. Bigger might be a good idea though.
3. Regular spark plugs are fine.
I got a question for you;
1. Why does everyone think tr55 is a "performance" plug? It's got iridium core, so does other normal ones you can buy for the same price or cheaper, are they performance? I just don't get all the hipe.
Old Jan 13, 2006 | 12:17 PM
Plug wires deliver energy. The higher the compression, the more power, the stronger spark you need. Stock wires should be OK. But why skimp?
For 400rwHP, I'd recommend a 52mm TB. Your looking at 475-480 flywheelHP. With the engine dyno testing I did with my setup, approaching 500 flywheelHP, the measured air flow would have maxed out a 52mm TB.
When you add HP, you need a colder plug. Old rule of thumb was one step colder for each 75HP. With modern computer controlled fuel injection, you can stretch the HP limit a bit. I would definitely run at least one step colder than stock with an engine approaching 500HP. I run either Autolite 104 (one step colder) or 103's (2 steps colder).
Who said anything about an Iridium plug? The TR55 is available in platinum, non-platinum and iridium.
Old Jan 13, 2006 | 12:31 PM
"White Knight"'s Avatar
and i looked at this because....
