Questions on adjusting RR with motor running.
Old Apr 16, 2003 | 07:01 AM
jpolz's Avatar
So what's the proper way to do this. I've already adjusted them once, so I guess I need to back off the rocker nut locks a few turns? Should I do the whole side and then after I've got them adjusted should a tighten down the locks afterwards?
Old Apr 16, 2003 | 10:42 AM
grygst76's Avatar
loosen until you hear it start to chatter and slowly tighten until it stops chattering; then go 1/8 tight more and lock it down go to the next. Do one side at a time (1 head) you can safely go 1/4 down.
Old Apr 16, 2003 | 11:10 AM
95_RipperZ's Avatar
Jeff, did you get the fans running?
Old Apr 16, 2003 | 11:18 AM
jpolz's Avatar
Not yet...but I verified that they work. I gournded the jumper where it hooks up to the PCM and they clicked on no problem. I think maybe my coolant system still has air in it, or maybe my PCM is buggy? I'm gonna look at that today. If need be, can we swap PCMs and see if that fixes it?
Old Apr 16, 2003 | 11:21 AM
95_RipperZ's Avatar
Ya we can do that. I should be home this weekend. Paintballing on sunday again.
Old Apr 16, 2003 | 11:24 AM
jpolz's Avatar
If i get all the kinks worked out of my car by sunday, I'll join you guys
jb4xx
Feb 2, 2015 10:00 PM
ChrisFrez
Jan 18, 2015 08:05 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
97z28k&N
Jan 9, 2015 04:58 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
