questions about different brands of injectors....
Old May 27, 2004 | 11:55 PM
bad95z28's Avatar
bosch, svo, ford motorsports, siemens-deka. i know that the svo's work well in our cars but what about the other brands. i think bosch and ford motorsports are the same, correct?? i am looking for 30s or possibly 36s. would one brand be better than the other?
Old May 28, 2004 | 12:09 AM
Bosch, SVO, FMS and Denso are all basically the same pintle-style injectors. Siemans are a "radius rod" style. Lucas makes an extremely fast "disc-style" injector. The stock Rochesters are a ball & seat design. They will all "work" in the LT1, as long as they are the right length, the right diameter on both ends, have the right type of electrical connector, and are the high impedance type. You can even use a low inpedance type, but need an external "black box" adapter to drive low impedance injectors with the factory PCM. Not necessary on a 30# or 36# injector.
When you move up to a 30# or 36# injector, you will need a reprogram, and that's when you tell the tuner what brand you are using, so that he can use the correct flow constant and the correct offsets.
Some interesting injector info on this site regarding the strengths and weaknesses of each type:
http://www.supras.com/~riemer/sonict...rs/RCtech.html
Old May 28, 2004 | 12:26 AM
bad95z28's Avatar
thanks, i have 24lb SVO's right now and I have used Tunercat for tuning purposes but i was just wondering what other brands i could look for as options. thanks for the help and the link.
chevy95z28
Jun 22, 2015 09:28 PM
mikey4play
Mar 15, 2015 11:45 AM
alliance12364
Mar 6, 2015 04:39 PM
97TA-WS6-Con
Jan 10, 2015 05:31 PM
Catmaigne
Dec 25, 2014 12:16 PM
