question for you pros
Old Jan 9, 2004 | 12:33 PM
airborneluva's Avatar
Question question for you pros
two questions for you guys:
When i was sitting in the drive through today my car started to sputter slightly. I was in neutral and Both my rpms and my oil pressure were dropping and rising sparatically. Rpms dropped just below the normal idle of 1k and oil pressure from 18 to 16 or so. The car never died tho. I just had an oil change, 10W30 and the temp outside is about 25 degrees. Any ideas?
Also, my low coolant light keeps coming on tho I am not low on coolant at all, pressure is good and i dont seem to have a leak. Light comes on about 15 min after a cold start.
As always, thanks in advance.
-Josh
Old Jan 9, 2004 | 12:35 PM
TraceZ's Avatar
What kind of car?
The low coolant problem is common. Try cleaning the sensor. If that doesnt work, replace it. dealer cost is $35.00.
Or... you can just unplug it, and check the coolant the old fassioned way.
Old Jan 9, 2004 | 12:36 PM
car is a 96 t/a, M6. 70k miles.
Old Jan 9, 2004 | 12:38 PM
TraceZ's Avatar
Is the SES light lit?
what are the codes?
is it still doing it, or did it correct itself?
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
cmyname1
Feb 19, 2015 08:38 PM
383TransAm
Parts Wanted
Feb 15, 2015 05:05 PM
