question on lt4 knock sensor
Old Jun 11, 2003 | 12:35 AM
Blue96z28's Avatar
question, if this is a pic of the lt4 sensor
go to gmparts direct and search for part #GM PART # 16214681
that looks to me like a huge *** square peice, isnt the factoty sensor on the lt1, like a goldish round peice that installs where the drain plug should be??????
Old Jun 11, 2003 | 12:37 AM
madwolf's Avatar
The round piece is the sensor. This is the knock module located in the PCM.
Old Jun 11, 2003 | 12:43 AM
Blue96z28's Avatar
so how much work is it to change that module, just pull out the pcm and plug that it or does the cover have to come off.....what it be better to just wait and get a chip and have it "desentsitized".......
Old Jun 11, 2003 | 12:45 AM
madwolf's Avatar
No "chips" on 96s. You can do it through programming on the PCM though.
Installing the module is pretty easy. There's a little cover on the pcm held in place by two bolts. Take those bolts off and voila.
Old Jun 11, 2003 | 12:47 AM
Blue96z28's Avatar
Smile
awsome, thanks gays, well guess that finishes up this tread
Old Jun 11, 2003 | 01:02 AM
94FlamdS10Blazr's Avatar
I got a question.(raises hand) I have the lt4 knock and a stock lt1 knock sensor, is this ok?
Old Jun 11, 2003 | 01:03 AM
madwolf's Avatar
Yep, it's OK as long as you don't have it the other way around. (stock lt1 knock module and lt4 knock sensor on a 94-95 car. Or even lt4 knock module and lt4 knock sensor....)
Old Jun 11, 2003 | 01:49 AM
Dave88LX's Avatar
Hey now! Callin' them that after they helped you!!!
Old Jun 11, 2003 | 02:28 AM
Blue96z28's Avatar
Exclamation
yeah i caught that too ,unfortunately it was already after i had posted it
Old Jun 11, 2003 | 02:30 AM
madwolf's Avatar
Hint: On the bottom right corner of each post, there's a "Edit/Delete" button.
Old Jun 11, 2003 | 02:46 AM
Blue96z28's Avatar
tru
***edit
e
Old Jun 11, 2003 | 07:55 AM
http://www.projecttransam.com/projects1.asp
HectorM52
Jul 30, 2017 11:46 AM
Jul 4, 2005 05:00 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
NJ SPEEDER
Jul 19, 2002 10:22 PM
