question on lt4 knock sensor
question, if this is a pic of the lt4 sensor
go to gmparts direct and search for part #GM PART # 16214681
that looks to me like a huge *** square peice, isnt the factoty sensor on the lt1, like a goldish round peice that installs where the drain plug should be??????
so how much work is it to change that module, just pull out the pcm and plug that it or does the cover have to come off.....what it be better to just wait and get a chip and have it "desentsitized".......
No "chips" on 96s. You can do it through programming on the PCM though.
Installing the module is pretty easy. There's a little cover on the pcm held in place by two bolts. Take those bolts off and voila.
Jul 4, 2005 05:00 PM
,unfortunately it was already after i had posted it
