Question on electric water pumps.
Old Jun 17, 2005 | 06:06 PM
  #16
ZMAN Z28's Avatar
Re: Question on electric water pumps.
I've had my CSI on for about 3 years now. The only problem I had was my fault. I didn't see I unplugged a wire. I have them routed better now. I recommend the elec water pumps. The CSI is less expensive.
Z
Old Jun 18, 2005 | 10:27 AM
  #17
RobbyRob's Avatar
Originally Posted by FastZinTennessee
It most certainly was the reason. The temperature sender for the dash gauge is located in the drivers side head. It showed the temperature of the coolant in the head going from 250* to low enough where it hardly registered. Within a day it was white smoking and losing coolant. Other than that the car had never overheated or had any problems before. So yes, I think it's fair to say the problem was a direct result of the waterpump. If you don't agree then that's fine, but from what I see it looks pretty obvious.
Did you not have a thremostat in? Because the t-stat would not like that happen unless it failed.
Old Jun 18, 2005 | 05:19 PM
  #18
FastZinTennessee's Avatar
The problem was not with the thermostat, the problem was that the pump was not circulating any water at all. I'm sure the thermostat was open due to how hot the motor was, and when the pump finally came on it pumped the hot coolant out and the relatively cool coolant in.
Old Jun 18, 2005 | 10:49 PM
  #19
Bersaglieri's Avatar
When I did my opti and went with Mechanical since it was so much more reliable, or supposed to be reliable. Its now a year later and I already had the mechanical leak all over the front of my engine, including opti, and garage floor, it was shot. I switched to the electric CSR(CSI) and have had no problems since. Plus I can tell the car revs and drives more effortlessly, a definate power increase. I'll post MPH gains next time I'm at the track. Its on a switch currently and I'll be getting the fail-safe kit soon, that goes has a LED and Buzzer go off when the temps get too high before damage occurs. I will probably never go back to mechanical now.
-Dustin-
Old Jun 19, 2005 | 08:39 PM
  #20
Cerwin Vega Fan's Avatar
How do you inbstall these warning lights?
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Queens94z28
Dec 20, 2014 09:11 PM
Zone
Jul 29, 2002 07:43 PM
