question "cc306"
question "cc306"
this is for the emission minded people,i have used this cam in the mid 90s in tpi applications and it barely passed emissions the ? here is will it pass in an Lt1,i know some folks dont care but for those of us that do this is the determining factor for the use of this cam!
Re: question "cc306"
i assume you need a sniffer test? i have heard of some people using the smog pump to pump air into the exhaust after the 02 sensors in the cat or somthing. i plan on passing with mine. use a more emission freindly tune as well.good luck.
yeah, we get probed out here more ways than one for sure i think i am gonna go for the hot cam or poss cc305,man i love the way the 306 pulls! i also have another cam that is 230 @.050 560 lift 110 lobe sep(286hr10) but i have heard LT1s like split duration cams better!!!!!!!!!!!!!!
Yes stock head LT1s like longer exhaust duration, especially with above stock lift and duration. Although a single pattern might make it easier to pass emissions. I'd go with CC305 if I were trying to pass emissions, with a 306 you'd have to pull some funky crap to get it to pass.
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
